B1 irregularity and pitch cut problem
Hello, For the wall shear force problem (BAP1), you need to increase the diameter of the horizontal reinforcements in the header and body area on the ground and 1st floor or decrease the reinforcement spacing. For B1 irregularity, you can enter AkX and AkY values from the Floor Parameters yourself, as ideCAD does not take the wall loads on the curtain. For detailed information on this subject, I suggest you to review the link below.
Hello (When my McAfee virus program is updated, it sees bv.rpt as a threat. (by giving Real Protect-SS! error) when I restore, I will delete the .exe after 10 seconds.) For this, I fixed the project with the demo program. My suggestions --I put columns on the sides of the curtains, --I made changes in the attic, (remove the middle curtain to the roof if you want) --Some tiles were deleted while adding the columns, --I fixed the B errors, In this case, the output is taken. --You can remove the attic wall loads and reduce the moving loads. --Make a solution with the ladder Unver ÖZCAN
