Yes, you are right, I think I misunderstood. -B1 irregularity refers to the Strength Irregularity Between Adjacent Floors.- If the cross-sectional areas of columns, walls, and walls on the i.floor are below 0.8(nth) when compared to an upper floor, the system stiffness must be increased. If the th is between 0.6-0.8, the R coefficient is multiplied by the 1.25th value as per article 2.3.2.3 of the regulation, which the program does automatically. In your project, you don't need to do anything because the th value is between 0.6-0.8. Since the effective shearing area of the wall calculated from the wall loads on the 1st floor in your project is higher than that of the ground floor, it is taken as zero as per article 2.3.2.3. If you want, you can define the effective shearing areas of the walls in each floor in the Akx and Aky lines in the Analysis Menu Floor parameters/Irregularities tab. Good work
