B problem in columns
cyln
Hello, I am currently at the beginning stage of idecad drawing. I am working on a project. I am getting a B problem from the columns. I read the messages in the forums and applied the suggested solutions, the error was not resolved, I would be very happy if my dear colleagues could share with me and enlighten me. The project is attached. Thanks in advance. Good luck with. Civil Eng. Ceylan Gunel
Hello, Attached is the document describing the solution methods of column beam connection safety errors. In your project, design a column on the curtain on the elevator tower floor and again as a curtain on the curtain. Again in these elements, a +150cm upper level was given to the curtains on the lower floor. When you move to the upper floor, adjust the curtain elevations as +150cm to ensure the continuity of the elements. Check from the perspective screen that there are no conflicts. After performing geometry control and analysis, you can also provide this control with displacement controls. On the 10th floor, remove the columns you added around the stairs. You can make short curtains on the elevator floor. You can ignore the 1/7 condition in the Geometry control in these elements.
God bless yasin sir. I will take into account the solutions you said and try that way. Thank you very much again.
