B error in the columns when the beam continuity is 30 degrees
Re: B error in the columns when the beam continuity is 30 degrees Arranging the angled beams continuously or separately affects whether the As2 value is taken as zero in the Joint Shear Safety calculation and accordingly the Ve calculation. You can review TDY 2007 item 3.5.1, 3.5.2 and figure 3.10. For the solution of Column Beam connection shear safety (B) problems, you can review the 9th item in the Frequently Asked Questions document, the link of which is given below. You can review TDY 2007 item 3.5.1, 3.5.2 and figure 3.10.
Good work
