good day, I couldn't fix the B error in the S64 column in the project, does anyone know? Also this is reporting with error B but municipality etc. at any stage can this B error cause trouble?
Hello. My suggestion is if you make the S64 column 45/45, you get rid of the (B) error or turn the column ninety degrees. Check out the link below to fix the B errors.
