b error in column
Hello. MY SUGGESTIONS: --Take the R coefficients 7 and 8 respectively --enter the stair loads --check the wall loads --slide the S6 column 20 cm to the left --Turn the S4 column into the wall --cent the beams and columns --the warning in the geometry control of the wall thickness on the ground floor (h=4 m) in line with --compare the structure by solving it as a semi-rigid diaphragm --Basically, there is a modeling error at the elevator location
You can review and model correctly from this tab in the form. Take it easy Unver ÖZCAN
Thank you very much, I tried to fulfill your suggestions, but I cannot change the location of the S6 column as you said. I am sending it again with the architectural project, I would be very happy if you look
