Axle problem in beam opening
ummet_gulay
Hello friends, when I take the beam expansion, it seems that there is a misalignment in the S11 column, but there is no such situation in the project, but there is no such situation in the project, the axis and the column are zero, but there is a slight angle in the beam and the column is drawn as a polygon column due to the crossing of this beam. I wonder if the reason is because there is a slight angle in the beam, if so, how can I fix it in this opening. It gives this problem to every column and axis in the frame part of the building. When I get the expansion, it is not something that can be fixed manually. We saw that if there is no solution, it is necessary, but it must be a solution.
"ummet_gulay":2fh37len" said:
Hi friends, when I take the beam expansion, it seems that there is a misalignment in the S11 column, but there is no such situation in the project, the axle and column are zero, but there is a slight angle in the beam, the column is drawn as a polygon column due to the crossing of this beam. I wonder if the reason is because there is a slight angle in the beam and if so, how can I fix it in this expansion. It gives this problem to every column and axis in the frame part of the structure. It is not a situation that can be corrected manually when I get the extension. We saw that if there is no solution, it is necessary, but there is a way to fix it.
Hi, Beam expansions, beam middle(theoretical) ) is made according to the actual geometry, taking into account the axis. The distance from the axis to the column edge on the first line is given as an intermediate measure. The total value is the width of the column. We do not have the opportunity to draw the intermediate dimension in the program.
