AXLE LINE COLOR SETTINGS DO NOT HOLD IN APPLICATIONS
btemel52
6.054 I HAVE AN ERROR OR I CAN'T ADJUST ME WHEN I MAKE THE APPLICATION AND PLAN DRAWING, I WANT TO MAKE THE AXLE ADJUSTMENTS INSIDE THE CONTOUR COLOR YELLOW WITHOUT THE CONTOUR COLOR GREEN.
THE ISSUE IS SOLVED, THE COLOR ADJUSTMENT OF THE AXLES CANNOT BE ADJUSTED WHILE RECORDING THE SHAFT. ALSO THANK YOU VERY MUCH TO FRIENDS WHO ATTENDED TO DWG IMPORT.
