Axial load too much problem
Additionally --D11 spaces were not appropriate. Put joists on the gap edges. If there is an elevator here, where will you place the elevator machine? change the modeling here, --Put a rib beam on the edge of the gaps in the rib slabs. Do not let the ribs pass through the gap, --Model with the ladder, --You can suspend the beams on the C1 axis, --If there is no wall, you can give live load on the rib beams. --Fix bugs in geometry control. Unver ÖZCAN
