Axial load capacity warning on steel roof truss
etriye
First of all, have a good work and have a nice day. In the project I am working on, I will present 3 different models to the owner, one of which is a system consisting of a truss reinforced concrete column and a steel column, the owner will apply whichever of these three is economical. /onedrive.live.com/?authkey=%21AGsfDX-UywonJ3M&cid=4B10C88935B9DC59&id=4B10C88935B9DC59%21659&parId=root&action=locate]https://onedrive.live.com/?authkey=%21A... Do I need to increase the sections to overcome this, or is there a point I missed that I can't see, thank you in advance for your interest... good work
Hello there; There was an error in the lovers in your modeling. I modeled it again. In your model, it is seen that your sections are insufficient due to the ductility level and the selection of the R coefficient, due to the fact that the reinforced concrete columns and steel columns are on the same floor. You can achieve a more economical result if you complete the design of the steel floor with normal ductility level and R=5 by making all the columns steel on the upper floor. In this model, you will need to define reinforced concrete or steel columns for your K and E axles, as in your first or last truss, in order to enlarge the lower and upper head sections of the truss and to solve the slenderness problem. Good work.
In the project that I added good days, I could not save the insufficiencies of the scissors, I do not want to enlarge the sections more, but I could not understand why.
Hello there; If you check the Deformations section after the analysis, you can determine where the problem originates from.
3-4 sections of the video analysis It's about design and combination design. You should definitely check it out. - Some of your scissors could not support the columns, if you enter a union, there is no problem. * A number of improvements have been made in your structure, please check it as an example. Good work.
