Axial Capacity Error
recepaligeldim
Hello, I just started using IdeCAD. I try to fix the mistakes in my projects as much as possible, but sometimes I get stuck. How can I correct the errors I received in my project, especially the Insufficient Axial Capacity error I got in the 1st basement. I think I have mistakes in some basic project inputs but I can't find my mistake. I'm open to suggestions as I'm just starting out. Thanks in advance. Project Link:
Hello My suggestions; --Dissolve the building with a semi-rigid diaphragm, (in my opinion, don't use the rigid diaphragm in any building.) -For a 14-floor building, create a frame for all the columns, (if the architectural project is not suitable, the architect should fix it.) --On curtains such as P13-14-24-25 create a frame, --Make UL curtains as a group, --Model/support the stairs and solve them together, -Check -4.8.5.1..2..3, --Check TS498-TS500 from the load security, --Elevator machine floor floors are not entered, --Enter the mezzanine floor that carries the elevator machine, (increase the live loads as well.) --Increase the diameter of the additional raft reinforcement, --Finish the calculation by making all finite element widths 0.25 m in the final calculation, --For column (B) errors [ b]Frequently asked questions and answers[/b]
, -- If the axial loads are insufficient, you can increase the column/wall dimensions, Ünver ÖZCAN
