Automatic cross-section intervention in the mold in Ver.6.52
serhatmuh
Hi Ver.6.52, we take a mold from the drawing menu and it automatically gives its own 1-1 and 2-2 sections. It's nice, but it creates its own automatic section line, do we have a chance to interfere with it (when we specify the name we give ourselves and the section line; Does it come out in the direction we want? ) Good work
Hello. You can enter the properties and change the settings from the menu that opens by marking the existing section line in the mold plan and pressing the right mouse button. Then you can re-create the section by marking the section line and clicking the "create section" command from the menu that appears by pressing the right mouse button. or; If you wish, you can create as many sections as you plan with the Mold-foundation plan command in the Drawing menu while in the formwork plan. Good work...
As you said, after taking the mold, you can mark the current cross-section line on the plan and press the right mouse button to enter its properties and change its settings from the menu that opens. Then you can re-create the section by marking the section line and clicking the "create section" command from the menu that appears by pressing the right mouse button. agreed on that ;) :arrow: but I mean can I see and play with these cross section lines in the main project?
As you know, there is a "refreshed and improved section" command in the main data entry. With the section command that works in its most general form, you get the sections you want, you can play with the features as you want. Then you can put it in the formwork plan, but I think the facilities we have developed for the formwork plan will be enough for you. At this point, considering the possibilities offered by the program, you can specify what is not meeting your needs.
