Hello Mr. Guray; - If you select the combinations after selecting the elements (select one from the same combination and right click select all), the combinations will be copied during copying. - You have the opportunity to use a combined section within the crosses. You can use the section you created from the sections section in the cross menu after creating a section by selecting Add a new section - combined section - Combined L from the sections section in the building tree. - If you want to remove the crosses from the screen, you can select the crosses and use the hide selected elements command from the filter section. You will appreciate that it would not be useful to add all the reinforced concrete and steel elements available in the program to the filter. If you need it especially intensely, I can forward it as a suggestion on this subject. - Since cross joins are created automatically, your joins have also arrived in cross copying. Therefore, the default values did not copy the old ones, but created them again. To copy the cross joins you have made, as I said before, you need to select those joins. - A detailed study will be carried out on cross-joints. Currently, it is in the first place in combinations in planning. - Your request for multi-cross has been noted. Good work.
