Attic flooring problem
teknikisler
1-) On terrace floors, in cases where the used areas are made of reinforced concrete and the other parts are made of wood, especially on L-shaped roofs, if there is an "A"-shaped skylight on the roof, a multi-plane floor plan emerges. Is there a way to identify this type of flooring? 2-) Again, on the roofs, due to the different room structure and drawing distances from the lower floors, a load-bearing wall must be built under some beams or a non-continuous column must be applied at the bottom. It is obvious that these two applications are unsubstantiated, but these types of applications are requested for many reasons. Can you help me to get an idea about this and how I can implement it in the program?
"teknikisler":1c6oax65" said:
1-) On terrace floors, in cases where the used areas are made of reinforced concrete and the other parts are made of wood, especially on L-shaped roofs, if there is an "A"-shaped skylight on the roof, a multi-plane floor plan emerges. Is there a way to define this type of flooring? 2-) Again on roofs, due to the different room structure and tensile distances from the lower floors, it is necessary to construct a load-bearing wall under some beams or to apply a non-continuing column below. This type of applications are requested. Can you help me to get an idea about this and how I can apply it in the program
Hello 1- The link below explains how to incline the floors.You can create the inclined surfaces that make up the roof with beams or slab edges.
2-One arm If you want to place it on the lower floor beam, you have to divide the supporting beam into two at the point where the column's nodal point comes. TDY. 2.3.2.4. The article contains the conditions for this situation. 2.3.2.4. Item b is applied automatically.
Thanks, good thing I hadn't seen this message. I want to ask one more thing . I am making a tile with dimensions (762 * 403). 20 cm thickness. It gives double reinforcement error. When I want to check the static results, the row with this tile has meaningless values that cover the whole row (like 169997777oooooooooooooooooo). Why does this happen? How can i solve it.
"teknikisler":2mwlmb6k" said:
Gives a double reinforcement error. When I want to check the static results, the row with this tile contains meaningless values that cover the entire row (like 169997777oooooooooooooooooooooo).
The problem occurs when there is a data error in the tiles. Follow the slab finite element lines shown during the slab analysis and see where the slab boundaries are broken. Check especially beam-beam, beam-panel junctions, if any. If you can't solve the problem, add the project to the message....
