In the ground floor ceiling, you can use the change I suggested regarding the hollow block directions for all floors. hang on long beams. It would be more accurate to overlap the short beams instead of the beam. so that you do not unnecessarily force the beams with a large span. a semi-rigid diaphragm analysis option can also be applied. I can't look at other issues. Good luck with...
