AS- ERROR ON CONTINUOUS BASICS
aliavcı
Hello friends, even though I enlarge the dimensions on the foundations, it gives the error of insufficient reinforcement. can you help me.
Re: can you help me to save the elements in my project hello friends, there are some elements that did not save in my project, I tried hard, it does not save, can you help?
Hello
"aliavcı":1do28hgk" said:
hello friends, there are elements in my project that did not save, I tried hard, it does not save, can you help?
My suggestions: --Check the coordinates of the place where the building will be made, (if you do not enter the location correctly, you can get very different results. ) --Make a semi-rigid solution, --1.Remove the basement floor rigidities, --Make a solution according to 4.8.5.1 in the modal analysis, --Check the item load safety-TS500, --Calculate all finite elements by 0.25 m. complete the account, Unver ÖZCAN
account; Complete the calculation by making all finite elements 0.25 m. hello, where do we do this, can you describe it from the idecad menus?
"aliavcı":238z4yd2" said:
Complete the calculation by making all finite elements 0.25 m. hello, can you describe how we do this from the idecad menus
Curtains, floors and rafts can basically change finite element widths from element properties. For example, to change the finite element width of all curtains in the system at once: -Make the perspective window full screen. -Click the Curtain command. -Click the "Select All" command. All Curtains will be selected. -Press CTRL+E. Curtain settings dialog -Change the finite element width in the Static/Reinforced Concrete tab in the dialog that opens -Click OK and exit the dialog.
Hello, I applied what you said, you can check it, but the curtains do not save, I would be very happy if you examine it and return to me.
"aliavcı":288qd765" said:
hi, I applied what you said, you can check, but the curtains do not save, I would appreciate it if you could review it and get back to me.
Hello, please select larger stirrup diameters in the curtain reinforcement selection dialog. For curtain cutting safety and possible solutions, you can review the knowledge base linked below:
[ url]https://idecad.atlassian.net/wiki/spaces/IBB/pages/851446299/Perde+kesme+g+venli+i+sa+lanm+yor[/url] Project notes; -Ground and 1st floor There is a relative floor drift problem in the Y direction. You can check the following links for the relative floor drift control and possible solutions.
You can review the links below for shear safety problems and possible solutions in columns.
-Tile finite element widths are also 25 cm. I recommend doing it. -TK37 continuous base does not connect to column S3. Make data entry in such a way that the main nodes are on the column. Good work
