The displacements, reinforcement amounts and forces of the dome and vault elements are examined in a 3D frame. To do this, press the right mouse button on the perspective view. From the menu that opens, click the 3D Click the frame line. The perspective view will become a wireframe and the Results display dialog will open. Check the Dome and Vault Results line. The diagram of the dome will appear in the 3D image. By marking AS1 and AS2, the reinforcement areas in the principal and minor directions can be seen, respectively. If the upper reinforcement areas option is selected, The diagram shows the amount of reinforcement in the upper part of the shell. If the option is not checked, the amount of reinforcement in the lower zones is shown. You can also see the numerical values of the dome by moving the mouse over the diagram. In addition, which color corresponds to which numerical value can be followed from the color palette in the perspective image. In the lower right corner of the perspective image click the download icon You can choose any installation status from the drop-down list. 1.4G+1.6Q loading will be the most negative for vault results. While AS1 and AS2 are marked, the line where the diameter and spacing can be defined is activated by clicking on the Existing reinforcement area line. By entering the reinforcement and spacing values on this line, simultaneous color change is observed in the graphic. When sufficient fields value is provided for the entered reinforcement amount, the image is painted with exactly the same color. This process is done both in the upper zone by clicking the upper reinforcement areas option, and for the lower zone by removing the option. In this way, you determine the required reinforcement for the dome for both tension and compression zones in the program. After this stage, you draw the element using the 2D drawing possibilities of the program.
