Hello, sensitive friends for the subject mentioned about the complaints I will write here again, please do not bother to explain this question to me because I share the same views and I am struggling with it seriously. My problem is that; The relevant raoportor in the municipality says that he wants curtain groups such as UTL to be defined as polygons in the relevant article of the regulation. Yes, he is right, we create curtain groups in idecad and we ensure that the calculation method is correct and we get results. Our rapporteur wants us to model this curtain as a polygon as in sta4. He states that otherwise we have made a mistake. He states that each program has its own rules but the calculation logic is the same, that is, they take the rules from the regulations, and that the element defined as a polygon column in idecad will serve as a column in the rollover calculations. I have told them that it will not appear as What I did, 1- I got an account report as a curtain group 2- I got an account report by leaving it as separate curtains, that is, breaking the group 3- I defined it as a polygon column and got a report (as it did not appear in the earthquake report) Now I have nothing to tell this engineer, as IDECAD, please take your 1 day. Could you tell us about your program.. IN BRIEF, THIS ROPOROTOR DOESN'T CONFID THAT THE PROJECTS MADE WITH IDECAD ARE CORRECT. HE SAID THIS MANY TIMES TODAY, I SAID THIS AT THE LAST TIME, SHOULD WE CHANGE OUR PROGRAM? THEY SAID NO, BUT TELL YOUR PROGRAMMERS TO TRY TO FIX THESE glitches. ---R SELECTION CONTROLS REDUCES VS. WRONG ACCORDING TO IT. ---WE DEFINE CURTAINS AS A POLYGON COLUMN, WHAT I SAID IS WRONG ACCORDING TO HIM, IT WAS PROVIDED WITH M0/6 AND M0/3, WHILE R WAS PROVIDED WITH 4/5 WHAT MORE.
