ottomancagatay
hello I have a question while analyzing the project It gives the error "TBDY item 3.3.1.1.B does not provide a rigid basement condition". How can I fix this error?[/b]"Ismail Hakki Feeds":25sitbuv" said:1) Solve by removing the rigid basement sign you marked in your building. Get a dynamic analysis report for this situation. Then analyze when the rigid basement is marked do it and get a dynamic analysis report. Find the ratio from the periods in the two reports. 2) For the beamless tiling solution, ideCAD Static v10.03 does everything "properly" as described in the regulation
Hello, analyze the floor that is considered rigid in the floor general settings dialog by unchecking the Rigid-X and Rigid-Y columns."KLVN":19b32qhh" said:hello, I have a question too. When analyzing the project, it gives the error "TBDY item 3.3.1.1.B does not provide rigid basement condition" How can I fix this error?[/b]
