erhanbaytak
Re: ideCAD Static IDS v10.20 *(10.20 New Version 14.05.2020) The 10.20 version turns itself off every five to ten minutes. This started after the update. I don't know if the problem is with the update.
I don't experience this problem in any project. I have this problem when I open the part with the default black background that appears on the screen. I get this problem without any drawing. //i.ibb.co/wNG6dRy/2020-06-14-10-46-50.png[/img] edit 1: I completely uninstalled and reinstalled the program, but this time it gives an error during the installation of MS C++ 2019 Redistributable. I have manually installed MS C++ 2019 Redistributable. I'm trying again now. I'll let you know."Ismail Hakki Besler":17y4icbf" said:There is no such systematic shutdown in the v10.20 version. Let them add the project they have a problem with under the title. Let's examine this problem together with remote access.
İsmail Hakkı Bey , I didn't have to try the template you sent. I've been using the program for a few hours just to be sure. I haven't had any problems. The solution is to remove the ideCAD program completely from the computer and manually"Ismail Hakki Besler":3tznueh2" said:This project is a black background template project. Could you upload this project and try it.
