Are all the beams in my project faulty?
kemalweb
Greetings, There are a few minor problems with my geometry control in the attached project. Also, the overall system isn't bad. However, after the analysis, error appears in all beams. This is my first time encountering something like this. What is the problem? Good work.
Hello. You should get the upper rigid basement number -3 instead of -1 because it's -1 and -2. It does not create a rigid basement in its basements. Also, you have taken all beam loads of 0,800 tf/m, which increases the residual strength of the system, but makes the results uneconomical. In addition, the console dimensions of the raft foundation have become large. Finally, when I looked at a symmetrical half of the system, I saw 10-13 studs. Although it is easy to say something without looking at the architectural project, it still seemed too much for me. Good work everyone...
I only changed the errors in the geometric control and the number of the rigid basement floor, only 2 beams give K error, and there is no problem when the system is fully arranged and the errors are cleared. good work
