ANGLE DIFFERENCE SMALL BEAM ADJUSTMENTS
DEAR FORUM OFFICIALS MY QUESTION IS ATTACHED TO THE PROJECT I HAVE SUPPLIED THE ANGLE DIFFERENCE IN THE GENERAL REINFORCED CONCRETE PARAMETERS CONTINUOUSLY ACCEPT THE SMALL BEAMS, WHILE I HAVE ZERO VALUE, WHEN I MADE 30 FLOOR GROUND GOODS WHEN WE REACH ZERO VALUE, THE EXACT SITUATION HAPPENS. THE CURTAINS ARE SAID WHILE THERE IS A CUTTING UNSAFE ON THE BEAM..I WOULD GET IF YOU GIVEN INFORMATION ABOUT THE SETTING. ALSO, HOW CAN WE GET RX=RY=8 IN SUCH BASED BUILDINGS, I WOULD LIKE TO GIVE YOU INFORMATION ON WHAT VALUE WE WILL RECEIVE, CONTINUOUSLY ACCEPT THIS ANGLE DIFFERENCE SMALL BEAMERS VALUE.
[Quote = "I [email protected]": emxzozkl "] DISTINGUISHED FORUM AUTHORIZED MY QUESTION EK SUN During the angle therebetween differences in GENERAL CONCRETE PARAMETERS IN THE PROJECT SMALL BEAM CONTINUOUS ACCEPT VALUE OF ZERO WHILE, 30 DO I GROUND FLOOR in K17 BEAM CUTTING distrust of surviving BUT ACT in the BASEMENT CUT UNSAFETY OCCUR. WHEN WE SET THE VALUE ZERO, THE EXACT SITUATION IS THE REVERSE. THE CURTAINS ARE SAID WHEN THE BEAM HAS CUT UNSAFETY.[/quote] This did not occur to me. So when option 30 is taken, 0 gives the same results. In both cases, the shear safety of the beam is K17. It gives a missing ace message on some curtains, K17 beams and some slabs. You have fixed the reinforcement in them, and you have also limited the diameters in the selection of reinforcement. To eliminate the missing As messages, remove the reinforcement fixings and choose a higher diameter, especially for slabs. On the K17 beam, 10 stirrups If you let the stirrup pick 10 Trace defect disappears. The corrected project is attached. You have given reinforcement and section tolerances in the project. If you didn't do it on purpose, you can set the values to zero in the Analysis settings.
"[email protected]":emxzozkl" said:
I WOULD LIKE TO GIVE YOU INFORMATION ABOUT THE SETTING. ALSO, CAN WE GET RX=RY=8 IN SUCH BASED BUILDINGS
There is a rigid basement in the system. The rigid basement number will be -1 in both directions and R coefficients will be 8 in both directions because there are no curtain elements that go to the upper floors except for the rigid basement
CONTINUOUSLY ACCEPT THIS ANGLE DIFFERENCE SMALL BEAMERS VALUE, UNDER WHICH CONDITIONS WE WILL GET THE INFORMATION WE WILL CONSIDER I LOVE IT.
Angle is used for beams that bend at a different angle but need to be drawn continuously. This value can be entered maximum 30 degrees in the program. If there are beams with angle difference but you want to be drawn continuously, you enter a value in that line. The value you will enter is the angle between the two beams you want to draw continuously.
