I cannot analyze in ideCAD demo static10 2019 version. I come across an article and it says that the demo is limited to 5 floors. After pressing OK, nothing happens. And so I can't analyze
Re: Idecad analysis You must be unable to analyze because you exceeded the number of floors and/or elements of the demo. Make the number of floors a maximum of 5, if there is an element limit, do not exceed it.
When the demo program is run, the following information message appears; The demo program is limited to 5 floors. In the warning dialog that appears in the next update. It will write: The structure you are analyzing has X floors. Analyze by wiping the layers after the 5th layer. With the demo version, up to 5 floors (including 5 floors) structures can be calculated. There is no restriction in terms of the number of column beam curtains. This is also clearly stated on the ideCAD website:
