analysis stopping error
mahmudkayra
friends, although there are no geometry errors in the attached project, the analysis is requested to be stopped and geometry control is requested.
Mr. mahmudkayra gives a jacobian error during analysis. There seems to be a problem in the junctions of K12-K47-K48 and K09-K27-K28 beams on the ground floor. Probably, when you correct the beam combinations, your problem of not being able to analyze will disappear.
In addition, check the calculus axles on both ribbed floors. Also, make the place you made as the tie beam as the Foundation beam and make the superstructure interactive when analyzing.
