Second; After choosing the ground class, I can't select a point from the map because I can't select a point from the map because I can't select a point from the map after I choose the ground class. When I enter this part manually, I encounter the third problem. [/ quote] Wizard pages are prepared in WEB page format. This may be caused by adblocking (adBlocker) programs or antivirus programs installed on your computer. Uninstall the add-ons installed in Internet explorer and check the following steps. - Make sure the ideCAD installation is OK, You can try to uninstall and reinstall the program. - Make Windows updates - Update Internet Explorer to the latest version (Must be 11 Version) - If you are using antivirus adblocker-style security software, deactivate them and try again. - If there are add-ons installed in Internet Explorer, disable the add-ons. After entering the latitude and longitude coordinates, "Offline" by clicking the " command You need to calculate the ctrum parameters automatically or get the information from the AFAD map via the "Online" command via the E-Government system.
"Hanifi Kösemen":7ms6bfdz" said:
Third, when you click on the "Floor General Settings" button at the top of the floor elevations stage, there is no change and neither does the forward button. Can you help. Thank you
Click the "General Settings" button and check the Floor Heights. When you press OK and continue, it will automatically go to the next page. It has been done this way to continue after checking the floor heights and elevations.
