Hello, Some determinations and suggestions for data entry in your project are as follows; S295,S310 etc. The columns are not defined in the basement. On the ground floor, raft flooring is placed between the columns S301-S302. All floors are considered rigid in the Floor General Settings. There are perimeter curtains only in the basement. Therefore, only define the basement as rigid. The Response Spectrum multiplier 3 is entered in the Analysis Settings/Basic ground Tab. It should be 1. You can set the Ductility level to high in the Analysis Settings and get the R coefficient of 7. P02 is entered with a thickness of 22 cm on the ground floor and 20 cm on the basement. Good work
