Hello. When I want to have an analysis done, it says that the analysis cannot be done and it says to check the geometry to determine the problem, but when I check the geometry, the problem does not appear, how can I solve it?
1. Adjust the distance (layout distance) of the window at the bottom of the P11 panel in the basement to the S11 column as 0.1 cm. In this case, the analysis will be complete. Good work
Thanks I got it done. Also, as there is no ampatage from both sides in the attached project, the ground safety stress does not save for the worst ground condition.
no, if you want to solve it as earthquake loading, leave an ampere from the 5 axis towards the y direction (30cm or so) so you can reduce the amplitude you leave in the y direction from the 1 axis, and you can get d=60 from an economic point of view.
