Analysis Options
doruk9261
This option, which I did not come across while solving small structures, first came to me when I was solving a 10-storey building. For which options should I make my analysis in this structure with ribbed upholstery? Note: A semi-rigid diaphragm is used.
You should use all analysis options in your first analysis. If you haven't made any changes to your tiles, for example, in other analyzes you will make after making changes to the project, you can save time by removing the tile analysis option and reducing the analysis time.
