Analysis Not Completed
uzooo
Hello!! While I can analyze the project I have sent according to the full rigid diaphragm, the analysis is not completed when I analyze according to the semi-rigid diaphragm. I get the error "Check your elements with the geometric control. There are short object errors in the geometric control, but unfortunately I can't fix it because it is not specified which one they are. Could you help me with this? ?As the most important problem, I get a B error in 3 columns on the ground floor. How can I fix this error without changing the column misalignment? Thanks in advance...
Mr. uzooo MY SUGGESTIONS 1- You used 50 and 25 cm wide beams on top of each other from column to column in the outer axes of the basement floor ceiling. When you delete the 25 cm beams, it analyzes according to the semi-rigid diaphragm, 2- To eliminate column (B) errors
, 3- Increase the column and curtain thicknesses in the 5.80 m high floor, 4- Let the rib beams center the columns then you will get rid of the (B) error, 5- Process the ladder, 6- Check the wall loads and live loads Good luck Ünver ÖZCAN
Thank you very much for your answer... I made my mistakes in line with what you said. When I make an elevator shaft and lower the curtain around it to -150 elevation, I get the error that the curtain does not provide cutting safety. I wonder if I made a mistake in the modeling.
[url = http: //s3.dosya.tc/server2/m19n70/projee.rar.html] http://s3.dosya.tc/server2/m19n70/projee.rar.html [/ url]
