Analysis help
adrian
HELLO FRIENDS, I CAN'T ANALYSIS IN A STUDY I MADE. CAN YOU HELP BY GIVING A WARNING DURING THE ANALYSIS. I ATTACHED the project B+Z+14-floor FILE THANKS IN NOW.
Re: ANALYSIS HELP says the system cannot be solved, check the geometry for the problem. After removing all the errors in the geometry control, I analyze again and it gives the same error again.
Re: ANALYSIS HELP I downloaded your file. I copied the first floor up to 48.90 m to the terrace level. system is being resolved. There may be a problem with your computer's ram. I would recommend a 16gb ram. by the way, your beam depth of 30 is not enough. How will the height be 30 with a 7-centimeter floor, hollow brick or foam? There is 20 or 25 hollow blocks, in general, in this case, your floor will either be 5 cm or 10 cm. your beams have a deflection problem.
Re: ANALYSIS HELP You are right, it may be due to ram, the computer's ram is low. In the Mediterranean region, we use a 23-gauge hollow block for flooring, but on the ground floors I plan to make a 32-gauge floor and use a 25-gauge hollow block.
