Your project has many connection errors. There are connection problems again in the pool area surrounded by curtains in 1 basement. Maybe you should model with high beams. There are 17th floor and 18th floor column beam connection errors. Again, there are curtain connection errors at some points on the floors. I suggest you dispose of it. Check out the bugs in the geometry check. In addition, you can see your errors with deformation in the analysis model on the three-dimensional screen. Take it easy, good work.
