Analysis errors when IDECAD8 is saved as old version
rgaltunbas
İDECAD.8 when DE SOLUTION YAPTIGIM PROJECT CONTROLS the YAPTIGIM TIME ANY RECOVERY The SECTIONS REPORT is NOT the APPLE SEE A PROBLEM NO BUT OLD VERSION 7:02 AS KAYDETTİGİ me SAME PROJECT RE-ANALYSIS YAPTIRDIG I RESCUE The CUT ELM those BEING .. CORRECTION OF HOW THE ISSUE ON BEKLİYORUM the aid of arkdaslar THE INFORMATION GOOD WORK
Re: Analysis error when IDECAD8 is saved as old version Hello, you know that in version 8, the wall height can be entered at the desired value. However, in version 7, there is no concept of wall height unless you read the data from the architectural program, the total wall value is entered. In your project, you have defined wall heights of 2 meters and 1 meter as far as I can see in some beams. When you save the project as 7 versions and open it again, the defined wall heights are not known for the reason I wrote above. 2.5m is taken by default. This is why the difference occurs. If you redefine the wall heights as you first entered, the difference will disappear. Can we find out what is the reason for you to enter the project at 8, save it as 7.020 and analyze again at 8?
Re: Analysis error when saving IDECAD8 as old version Thank you for your answer, Hakan, my reason for saving the project as version 7 is. The friend who will check is idecad because the old version is dangil. They want me to save it as a version. I also have the cause of the problem. To detect. I saved it in version 7 and had it analyzed at 8 to determine if it was related to the computer being analyzed.
