Analysis causes the program to report errors
platon24
In this file, where is the error that causes the program to freeze during the analysis? I am using idecad 8 latest version
event log history Version 0.8.1.3 of ideCAD_Statik_8.exe stopped working with Windows and was closed. Check the history of the issue in the Security and Maintenance control panel to see if there is more information about the issue. Process ID: b14 Start Time: 01d10280df7553cb End Time: 4294967295 Application Path: C:\Program Files\ideCAD\ideCAD Static 8\ideCAD_Static_8.exe Report ID: 6aeaa4c9-6e74-1re5-b6db-50465d5b662 package-related application ID: Bad application name: ideCAD_Statik_8.exe, version: 0.8.1.3, timestamp: 0x55f7be51 Bad module name: ntdll.dll, version: 10.0.10240.16430, timestamp: 0x55c59f92 Exception code: 0xc0000374 Error offset 0x00000000000ea28c Bad process id: 0x6bc Application start time: 0x01d102812f7e12e8 Bad application path: C:\Program Files\ideCAD\ideCAD Static 8\ideCAD_Static_8.exe Bad module path: C:\WINDOWS\SYSTEM32\ntdll.dll Report ID: 0e63a183-d51d-41d -b27a-c89d093c666a Bad package full name: Application ID related to bad package:
