ANALYSIS AND PARAMETER SETTINGS
OUR DEAR FORUM OFFICIALS I WANT TO ASK ABOUT USING THE BUTTON TO INCREASE GROUND SAFETY by 50% WHEN USING EARTHQUAKE LOADS IN THE ANALYSIS SETTINGS IN THE 1st EARTHQUAKE SECTION C2, Z3 ON A FLOOR, OUR AC CANNOT USE THIS GROUND SAFETY 50%. 2.Water I WHEREAS without girders RAFT SLAB ANALYSIS 14 LUX IRON 15 CALL LEARNED A PROJECT in MİN.ASAL PULL PURSANTAJ in MAT FLOOR PARAMETERS SETTING 0.0025 WHILE, 0002 AS, change ANALYSIS DO I RAFT My SLABS 14 LUX IRON 27 CM TOGETHER TO ALLOW has TO ACABA COLUMN BEAM SLAB PURSANTAJ AYARLAAR the HOW CAN I CHANGE? SOME CHANGES ARE OBSERVED IN THE REINFORCEMENTS. I HAVE RECEIVED VALUES FROM TS500. MY REQUESTS ARE THE OPINIONS OF PERSONS WHO HAVE BEEN MASTERED ON THE PROJECT FOR YEARS LIKE YOU. THANK YOU FOR YOUR INTEREST NOW.
I think it can be increased by 50% because the regulation allows it, but I don't know how much it can be increased in general, but in the regulation it is allowed on other floors, except for the Z4 type floor.
The regulation does not allow an increase in grade 1 zones for Class D floors, but allows a 50% increase in other floors and areas. However, do not use it, especially on silty, clayey, high water levels, that is, where there is a risk of liquefaction. If there is liquefaction under earthquake load, on the contrary, there will be a decrease in the bearing capacity of the ground. I do not find this issue very correct in the regulation because our engineer friends are not experienced in the ground. Based on this substance, they can reach dangerous conclusions. Attached, I see as a good resource on these issues, Prof. Cinioğlu has a seminar document. I recommend that all our engineers about the ground read it carefully. Read all of them but read chapter 4 specifically for the above topic. Greetings
