mehmetserhat
When I opened a project made with ide ver 5.551 with ide 7.017, I made the necessary corrections after checking the geometry for analysis. There is no error in the result of the geometry control, but when the analysis is done, it says that geometry control should be done, not modal analysis. When I delete everything in the coordinates given by the program and analyze it, it gives the same error even though there is nothing in those coordinates. The strangest part of the job is that after analyzing a few times without changing anything, it completes the analysis and gives results, but this time it does not autocade export the drawings. I would be very happy if you could help me with this. take it easy good work
