"ftthylmz":3hra0lve" said:
version 8 includes 'supporting condition for solution with structure'. I understand that you do not have such a feature from what you said, did I misunderstand, did you want to tell something else? My main question is that I want to solve the ladder and the building together in the project I sent. I made the support on the ladder accordingly. 1-Are my support conditions correct for the solution with the structure? 3- In such a solution, is it necessary to enter the stair load to the relevant elements?
In Ver 8, stair supports cannot be arranged together with the building according to the solution conditions. Arrange the supports and enter the stair loads according to the solution conditions independent of the structure.
2-Since I solved the ladder together with the structure, I did my analysis by creating a semi-rigid diaphragm, right?
You can make a semi-rigid solution. Even if the stair supports are arranged according to the solution conditions independent of the structure, a semi-rigid diaphragm solution can be made. Good work
