if it is on the ground, there is already a filling under it. If you are going to do the calculation, make the inclined floor and give the load accordingly. make the drawing at 0 elevation, then you can select the objects with the bevel tool under the tiling command and give the bevel. easy, also this is a rough idea because I don't know any details about the structure you have, this account may not even be needed.
