Hello there; In a 4 storey project (there are elevator curtains in one direction) in the 3rd degree earthquake zone, the ductility level is normal, when I choose R=4; I get the warning "Normal system is selected, but the ratio of the sum of the wall shear forces to the total shear force is less than 0,75". The regulation allows the normal system of ductility level without curtains in the third and fourth degree seismic zones under the conditions (height limit) specified in paragraphs a and b of 2.5.1.6. And again in 2.5.3.te, it can be done above the height limits, but it makes it necessary to use SDN or SDY curtains. Then 2.5.3.1. In the case of using SDN curtains, Alpha S >0.75 is required. According to the aforementioned articles of the regulation, I think that the Alpha S > 0.75 condition should not be sought in this project. Because, in case of using SDN curtains in TDY Article 2.5.3.1, Alpha S >0.75 requirement is stipulated in Article 2.5.1.6. I think it is desirable if the height limits defined in paragraphs a and b are made. (This is what I understand from the regulation) I wonder if I'm wrong! Thank you in advance for your comments and suggestions.
