Alpha less than 0.7
hatice.mert
I can't get rid of the alfai warning in my project. I solved it yesterday without any problems, but the program froze and closed, I lost the works. Same again I made the entries but it keeps giving an error. Can you help me, is there a problem with my data entry?
Dear hatice.mert * Do not make such large gaps with the slab gap command. (3rd floor stairway, ground floor stairway) * Why did you break the continuity on the normal floors in the building? Is it that important to break the ties of columns s6-s8 and s12-s16? * The direction of all columns without exception is in the Y direction. You should arrange the columns as staggered as possible. * Moreover, in the console part, the column is not connected in the x direction. p4, p19 * You have made cantilever beams from the s3 column on the mezzanine floor. Dear Mert, There can be much more to be said about this project. I think you should rework it and give it a good overhaul. It seems very normal for the alpha to appear this way under these conditions. You can clear some of your doubts by talking to the architect. Maybe it can allow for the beams you're afraid to do. Overhaul the column placement. Try to make columns in the X direction, but return to square columns. Pay attention to the continuities. Console balconies in this opening deflect. I advise you to take precautions. I think that's enough for now. Good work. N. YILMAZ
Hello, I would recommend you to examine the article DY 2007 3.3.6. (For the case of Alpha) I agree with what Nedim Bey said, you should especially connect the columns that you broke the continuity with, and make staggering in the columns. You can turn large floor spaces (stairwells, etc.) with beams.
