Advice about the project
ssesli
Hello, I haven't moved on to the details (wall loads, etc.) on the project yet, but I would like to get your opinions. I could not remove the b error in the polygon column. Do you think it should be done by defining curtains? In hollow block projects, I tried to make the outer beams horizontal for the first time, and there is a spring beam test. I would be grateful if you share about these issues and other problems you see. Thanks
For the b error: I usually fix the problem when I increase the concrete class by one level in the projects I do, if this does not happen, you should enlarge the polygon column sections. Good work
First of all, I would like to point out that the superstructure interactive solution is marked, but there is no basic data entry. Even if you correct the B errors now, your system will change a lot when you enter the foundation. *I strongly recommend that you make the beams on the outer walls deep. It reduces deformations. *I think the actions to be done with polygon columns should be to reduce the beam reinforcements or to press the beam from a different place. *Your spring beam definition is successful, some beams are too tight, it can be edited. Best regards.
Although I defined the basis, there was no change. Should I define a panel instead of an ooligon column?
