Adjusting Rebar Length
oguzhanyetik
Hello. When I take mold and datay drawings, the program approaches with precision and shows the lengths of the donuts, for example 180.1 cm. Is there a programmatic solution instead of manually correcting these lengths? On another issue, reinforcement lengths show 601 cm, for example, in reinforcement quantities. How can we fix this in 600 cm or 605 cm as much as possible in the form of 5 cm and its multiples without doing it manually in the program? Note: The fractions are often directly related to the axis and column placement. I asked because I was curious about these examples. Thank you for your interest..
Hello, If the inter-axle and inter-belt lengths entered in the data entry are fractional, these lengths will be fractional in the die drawing. Considering these fractions in data entry, you should adjust the lengths accordingly. The option to adjust the reinforcement lengths as 5 cm and its multiples is in our user requests list.
You said, "The option to adjust the reinforcement lengths as 5 cm and its multiples is on our user requests list." I wonder in which version this option will be given or is it possible to tell a time? I first used 8.504 and now I am using 8.61. As far as I know, they don't exist.
"oguzhanyetik":1avxek29" said:
"You said, "The option to adjust the reinforcement lengths as 5 cm and its multiples is in our list of user requests." As far as I know, they don't exist.
Hello, As you said, there is no such option in current versions, it is not possible to say at a time.
