"ssesli":30dod68p" said:Hi, I want my company's logo to be added automatically like the IdeCAD logo in the Program analysis window in the title files created in the windows that we draw. The " folder contains the title blocks used by the program. You can open these files with the blk extension, make the changes you want and save them again. Create your logo with lines and place it in the blk file you want.
You can download the blk file in ideCAD, not in autocad. You need to edit it in. Draw your logo in the program as a line or import it if you have a ready dwg. The entire log must be drawn with a line. You can open the blk files under the "Annotations" folder with paste from the file. Put your logo anywhere you want. You can save it again as a block with copy to file. In this way, you can change the ready-made letterhead files.Unfortunately, I can't add a picture because I am not at my computer..."ssesli":1k44lewe" said:Thanks for your explanation. But I couldn't open and edit the .blk file related to Autocad. I would be grateful if you could write a little guide if possible. Thanks
Thank you. It was pretty self explanatory. Sent from my SM-G925F using Tapatalk"HakanŞahin":1dksnz6q" said:You need to edit the blk file inside ideCAD, not autocad. Draw your logo as a line in the program or import it if you have a ready dwg. The entire log must be drawn with a line. You can open the blk files under the "Annotations" folder with paste from the file. Put your logo wherever you want. You can save it again as a block with copy to file. In this way, you can change the ready letterhead files. Unfortunately, I can't add a picture right now because I'm not at my computer..."voice":1dksnz6q" said:Thanks for your explanation. But I could not open and edit the related .blk file with Autocad. If possible, I would be grateful if you could write a small guide. Thanks
