Active scan and section scan
mustafadisci
Active scanning and section scanning are very common in my project, the scanned part is very black in the output, because I cannot increase the active scanning range, it gives the drawing dark. Where can I change the section scans before and after the drawing? help please.
- Since the scans used in the object drawings in the program are bitmap (picture) scans, their intervals cannot be interfered with. Unchecking the "Print all Colors as black" option in the Plotter Settings dialog when printing, or unchecking the Disable Grayscale printing option in the Printer Settings dialog may prevent scans from outputting as black. To change the section scans in the mold plan; Delete existing segments. Double-click the section line. The static section properties dialog will open. Make the necessary adjustments and exit the dialog. Place your section by selecting the section line and clicking the "Create section" line from the right-click menu. Good work
Thank you very much for your answer :) we don't always get the printouts, sometimes we send out projects, it's hard to repeat every time. Can we specify a standard scan for the section and have it drawn automatically? It is not important that the reinforced concrete sections are bitmaps in the program, they come as bitmaps on the drawing screen, and when we choose them one by one and want to change the scanning type or scanning method, we have problems. I wonder if there is a practical autocad-like way to do this. good work..
"mustafadisci":f4d3a1h3" said:
thanks a lot for your answer:) we don't always get the printouts, but sometimes we send out the project, it's hard to repeat every time. Sometimes we forget. Can we specify a standard scan for the section and have it drawn automatically. It is not important that the reinforced concrete sections are bitmaps in the program, they come as bitmaps on the drawing screen, and when we want to select them one by one and change the scan type or scan style, we have problems. Good work..
In order not to change the section scans every time; -Open a new project. -Click the Mold plan line from the Drawing Menu to get the mold plan. -Click the Drawing/Mold Basic Plan section command in the mold plan window and draw a section line. - Properties by double-clicking the section line enter what. Make the desired edits and exit the dialog. -Select the section line and click the Modify/Get Settings from Entity command. -Delete the pattern plan window and save the project as a template project. Now, when you create a project using this template, static sections will appear according to the settings you have made. Good work
