HELLO THERE. IN THE PROJECTS I HAVE DONE, THE REINFORCEMENTS ARE NEARLY THE SAME AND VERY CLOSE TO EACH OTHER, FOR EXAMPLE, ALL DOUBLE-SIDED FLOORINGS IN A PROJECT GENERALLY CAME 40 TOGETHER. DO YOU HAVE A PROBLEM....
HELLO. IN THE PROJECTS I HAVE DONE, THE REINFORCEMENTS ARE NEARLY THE SAME AND VERY CLOSE TO EACH OTHER. FOR example, ALL THE DUAL-DIRECTIONAL PROJECTS ARE ONE IN ONE PROJECT. DOES IT EXIST....
Maximum spacing for slabs is 1.5d or 20 cm. Therefore, the spacing value from flat reinforcement to flat reinforcement or from pile to pillar is 3d or 40 cm. For slabs to be 40 cm, your slab height must be 40/3'= It must be entered greater than 13.3 cm and the reinforcement price found from the calculation moment must be less than the minimum purchase price. For minimum conditions, check the Parameters/Slab Parameters. If you press the F1 key while in the slab parameters dialog, you can access detailed information about the subject. You can evaluate in the light of this information. studies
