ACCEPTED INTERNATIONAL ARTICLE USING IDE CAD
hakanyalciner
1-IN THE ATTACHED FILE, SOME OF THE ARTICLE WRITTEN USING IDE CAD 5 ENTERPRISE AND WHICH WINNED TO ENTER THE TOP 5 AT THE CONFERENCE ORGANIZED IN PORTUGAL LISBON (International Conference on Structural Engineering Dynamics ICEDyn 2009) IS AVAILABLE. BECAUSE THE ARTICLE IS QUALIFIED TO BE SENT TO THE INTERNATIONAL JOURNAL, WE CAN ONLY SHARE SOME OF IT WITH YOU. 2-IDE CAD DEFINITELY SHOWN WHICH IS THE PROGRAM THAT GIVEN THE BEST RESULTS (time history analysis) AGAIN AT THIS STUDIO AND MADE IT VERY EASY TO THE RESEARCHERS, THEREFORE. WE KNOW A DEBT. 3- IN THIS ARTICLE, THE BEHAVIORS OF AN EXISTING BUILDING BEFORE AND AFTER REINFORCEMENT ACCORDING TO FEMA 356 AND FEMA BSO STANDARDS ARE SUMMARY. TIME HISTORY ANALYSIS WAS APPLIED TO THE EXISTING STRUCTURE AND THEN THE STRENGTHENED STRUCTURE, USING 20 DIFFERENT EARTHQUAKE MOVEMENT RECORDS TO THE EXISTING STRUCTURE. 4- FOLLOWING TABLE 3 IN THE ARTICLE, IT CAN BE SEEN HOW IMPORTANT THE PUSH-OVER ANALYSIS IS WHEN MAKING REINFORCEMENT. STRUCTURED, STRENGTHENED BY LINEAR STATIC ANALYSIS, DID INSUFFICIENT BEHAVIOR IN TIME HISTORY AND PUSH ANALYSIS. 5-RESULT, IT HAS RE-STATED HOW IMPORTANT FEMA 356 BSO STANDARD, PUSH ANALYSIS, AND TIME TIMING ANALYSIS IN FEATURE LED WERE GIVEN WHEN DESIGNING. WHEN IT IS POSSIBLE TO GIVE ADVERSE RESULTS, RELYING ON THE RESULT OF TIME DEFINITION ANALYSIS WILL BE A MORE REAL APPROACH. 6- WE FOLLOW MANY REQUESTS FROM THE FORM, ESPECIALLY FOR DRAWING DETAILS FOR IDE CAD 6. CONCERNED THAT THE IDE CAD 6 IS MORE IMPORTANT THAN THE DRAWING DEFINITION. STAGED (CONSIDERING THE CORROSION EFFECT, ) IT IS POSSIBLE TO SEE THE PUSH ANALYSIS.
I would like to congratulate our teacher, who first published this article, and then the ideCAD team, who helped us make our voices heard in international studies. I hope that in a very short time, it will be the world's leading engineering program. Best regards...
Friends, I have read the comments and I would like to talk about a few things about a very important comment that caught my attention. Before I start my article, I would like to thank Hakan, he made a very good point. Indeed, ide cad is a static program of good quality, but I think the more important thing here is not to model a building, but as Hakan has mentioned, push over (push over analysis and time history analysis) gives us more realistic values. After making the static calculation of an existing building or a new building, I think it is absolutely necessary to perform push over and time history analysis. because we can have clearer information about the behavior of our building. It clearly shows us which elements have cases such as collapse, leakage or plastic jointing and helps us to take the necessary measures. A building may have been designed incorrectly or it may be in accordance with the earthquake regulations of that day, but it may not be suitable now. By doing push over analysis, we can have information about the behavior of our building.
