First of all, I wish you a good work. I have a few questions about SILO FOUNDATION modeling.... First of all, let me give you some information about the silo. Our silo is a STEEL silo from 0mt to 6mt on steel legs and then from 6m to 15m with 3 closed eyes. I took the participation coefficient as n=0.80 in idecad and we have approximately 180 tons of silos (dry material inside + equipment + steel skeleton) my questions for which I am waiting for suggestions 1-) Is it correct to model this as a live load since there is an increase and decrease in the level in the silo over time? 2-) in my modeling, I defined 6+4.5 meters = 10.5 meters of slab on the remaining part (the part where the 9-meter load is) on the 0-6 mt range, I loaded it on it, in order to calculate the tipping for the full silo, 3-) when it comes to the ground value, Z2 is 17 tons. around but I took the Z3 15 tons values to stay safe. Ao=0.30 and Rx=Ry=4 Steel silo foundation. ***If I could not find any source about the silo, I would be glad if you can share it ***When I model in the handle, the first period in the modal analysis = WHEN I MODEL AS STEEL=0.15, so it saves me when I calculate manually, but I still got stuck with idecadde, TOP BUILDING INTERACTIVE SOLUTION If I do it like this, it saves from tipping If I do it INTERACTIVE, the superstructure does not save it from overturning... I'm waiting for your suggestions. I wonder if the entire mass is included in the system as a protective moment in the superstructure interactive solution Is there a point I missed or I am waiting for your suggestions Thanks in advance, I wish you a good work
