About the cork floor space
mgondem
]Hello, in my attached project, the other floors with lower floor beams are requested to be in the form of cork flooring. The project provides as such, but; 1- There are stairs and elevator at the building. When I leave a space here, the beam must be thrown, and when I throw a beam, I get dozens of errors. 2- There is an air gap behind the elevator in the center of the building, I want to make a beam for the brick wall to be built between the elevator shaft and the air gap. but I have no idea how to do it. It gives an error when the elevator turns completely around. 3- I am solving cork flooring for the first time, I would appreciate it if you could take a look at my project for possible mistakes. Thanks in advance to those who will help. Stay well.
Hello My Suggestions -- 1. There is no curtain on the basement floor, remove the rigid x and y ticks, -- GJ like in the attic floor, put the beams between the 3-7 axes on all floors, let it be column-beam flooring, -- Hole the middle staircase and the elevator and the back space. take it as a linear load, -- Give the load of the 20 cm walls as a linear load, -- Solve the stairs together with the building, -- Take the middle spiral staircase 25 cm to the left and put a beam between the columns S9-10-18-19, -- The floor thickness seems a bit too much , can be reduced, -- If the last suggestion does not save, curtain around the stairs and elevator. Take it easy Unver ÖZCAN
Unver, first of all, thank you for your help. I applied your suggestions, most of the errors in the project were fixed. But there are two issues that stuck in my mind, I would appreciate if you can help. 1. When I was trying to solve the stairs together with the building, I was creating stairs and doing stair analysis. Do I need to do anything other than that? 2. I could not reduce the thickness of the slab. When I made a slab thickness of 25 cm in my mind, in the first case it gave upper and lower reinforcement like raft flooring (with a coffee table in between), in the last case it gives a single reinforcement like flooring. Is there a setting for this? Why can it be caused? Good luck with.
