about the beams in the stairwell
mhmt_ali
Hi, in the project I have done below, since double beams are on top of each other on the stair landing, it gives an error on the curtain where the beams are mounted. What can I do to avoid this error. I would be glad if you help.
ğlu_a_blok_sta_.ide7.html
Hello, In your project, the elevation of the intermediate landing slabs is not compatible with the beams to which they are connected. (It is given as a warning in the geometry control) The non-beam edge of these slabs should be created using the slab edge. (Or instead of defining the slab, a load definition can be made for the relevant beams.) If the intermediate landing slabs are deleted or not operated as a rigid diaphragm (The option to create rigid diaphragm will be checked in the tiling properties/static tab) shear force issue on curtains is resolved. Good work
