In the rafter raft, the program distributes the column and wall normal forces coming from the superstructure to the raft area, and loads and solves the rafts separately from the foundation beams as a supported system. In other words, it works as an inverted beam flooring system. This form of calculation is for the analysis of foundation beams and foundation slabs and for concrete dimensioning. In this case, the carrier elements in the superstructure are considered built-in. Since the total weight of the superstructure is distributed to the rafter rafters, point stresses are not observed under the columns.
