Fatihcelal
Hello; I would appreciate if you could help with the following issues; 1. Should we leave some space between the roof crosses and the purlins in truss roof systems. Is there a load on the crosses due to the deflection of the purlin? (Is it like 1 cm without touching the cross and the purlin, or 3-4 cm according to the highest deflection of the purlin) In 2 cases, the results of the crosses It turns out very different 2. In scissor systems, we pull back the ridge and brook purlin by 10-15 cm. While forming the roof diagonal, we place them according to the nodal points of the scissors. When we pull back 10-15 cm to align the end points of the crosses with the purlins (cross end node points, When we bring the purlin to the nodal points) a very high rate of axial force is formed in the purlins. Should it be obeyed to the scissor joint or to the purlins? 3. Is it true that in the same loading combination of X-shaped roof braces, all elements are tensioned or all elements are pressurized? 4. The design report of the combination made by combining the 2 cross ends and the scissor upper head while making the Cross End joint is not formed. When we combine the cross ends and the scissor head one by one, the report is formed. In 2 cases, the operation of the scissors changes. Is there a deficiency here? 5. In scissor systems, when the purlins are continuous, the deflection and capacity calculations of the ridge and brook purlin are made incorrectly, there is no problem in the other intermediate purlins. (Calculations are made for the entire continuous purlin length, such as 15m-30 m). We do cross placement in the last range. Would it be wrong if we skip the first and last range and place the second range? What are the benefits of cross placement to the first range. 7. How should we choose the R coefficient and the ductility coefficient when the braces do not continue in the vertical plane when only the diagonal is used on the roof. Thank you in advance for your interest.
